2 members (delky, Steelonsteel),
235
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2008 Posts: 283 Shop Shark | | Shop Shark Joined: Oct 2008 Posts: 283 | What was the difference between a normal 283 and a heavy duty 283, between the years 1955 and 1959? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | there was no 283 until mid-57, then the 3 different 283s weren't really much different, mostly the name  Bill | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | If you're talking truck 283s, according to the manual, looks like compression ratio (8.5 on LD, 8.0 on HD), camshaft timing, and the oil pan (5 vs 6 quart capacity). It should be noted, there were no 283s in '55-56, and in '57 it was only available in 2 ton and larger in trucks, US pickups and 1.5 tons didn't get them until '58.
Bill Burmeister | | | | | Joined: Oct 2008 Posts: 283 Shop Shark | | Shop Shark Joined: Oct 2008 Posts: 283 | If you're talking truck 283s, according to the manual, looks like compression ratio (8.5 on LD, 8.0 on HD), camshaft timing, and the oil pan (5 vs 6 quart capacity). It should be noted, there were no 283s in '55-56, and in '57 it was only available in 2 ton and larger in trucks, US pickups and 1.5 tons didn't get them until '58. There was a quadjet carb available, did it matter which engine option or was the carb it's own option? Is interesting because there were 2 different engine colors, for the HD vs LD. | | | | | Joined: Jul 2008 Posts: 326 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 326 | I don't think that the Quadrajet came out until the 60's. The 4 barrel on the 1957 283 was probably a Carter. There was also a dual 4 barrel and fuel injection option for the cars only.
SimS | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | the early 4 brl was a rochester 4gc ron | | | | | Joined: Oct 2008 Posts: 283 Shop Shark | | Shop Shark Joined: Oct 2008 Posts: 283 | the early 4 brl was a rochester 4gc ron Was the 4 barrel a separate option or was it part of the HD engine? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | the Roch was optional on all V8s, car [4GC] and truck [4G] ... the shop manual is an excellent resource for anyone with an old truck curious about details, it covers all the bases  Bill | | | | | Joined: Jul 2002 Posts: 165 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 165 | I beleive a 283 with 4 barrel came with a different cam and heads and distributor also. | | | | | Joined: Jul 2008 Posts: 326 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 326 | I think the 4 barrel option was called "Power Pack". Jeez the 50+ year ago memories are fading fast. I think the heads were something different for sure. As a street racing kids in the 60's we were always looking at the casting marks in the front of the heads to determine the "hot setup". I think this was the case for cars. I don't know if the trucks got the "power pack" stuff.
SimS | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Depending on the year, the Power Pack option could be either a singe 4bbl or dual 4bbls, with special heads and camshaft. To my knowlege, there was no Power Pack type option for trucks, there was a 4bbl option on the Taskmaster 283, which would make it a Super Taskmaster. That engine was only found in 2 ton and larger trucks.
