| | | Forums66 Topics128,080 Posts1,056,315 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | I removed the seat glide/floor mounts and discovered that the driverside front mount is broken at the rear rivet (Pulled lose and is bent). I don't think there is a way to fix this short of tack welding so it may be easier to simply replace the whole unit. Any body gto a spare I can buy? OR Any ideas? | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | I have a number of good, used factory-correct bench seat glide assemblies, so please let me know if you still need one. Thanks for the opportunity and Happy Holidays. | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | Tony,
I'll call you today. Thanks | | | | | Joined: May 2010 Posts: 162 'Bolter | | 'Bolter Joined: May 2010 Posts: 162 | Tony, Do you have any bench seats for a 60 chevy truck. My springs are shot and in need of repair or replacement. Did you get my e-mail about the headlight bezel? | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | I'm ordering one from Tony. | | | | | Joined: May 2009 Posts: 47 New Guy | | New Guy Joined: May 2009 Posts: 47 | You can buy new springs by the roll. It is used for some sofas.Has a s pattern similar to factory springs. need grinder to cut springs to length, they work great.I paid about $70.00 Canadian for a roll at a upolstery place. 1 roll will do a lot of seats. | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | The springs are in great shap. I think someone must have redone them before, which is great for me. I'm hoping to bring the seat out to the shop on Tuesday. | | |
