3 members (wilbur53, JW51, Otto Skorzeny), 150 guests, and 5 robots.
Topics128,088
Posts1,056,124
Members48,435
#705375 12/21/2010 11:19 PM
What was the difference between a normal 283 and a heavy duty 283, between the years 1955 and 1959?
GMCAMARO #705382 12/21/2010 11:33 PM
there was no 283 until mid-57, then the 3 different 283s weren't really much different, mostly the name wink
GMCAMARO #705383 12/21/2010 11:33 PM
If you're talking truck 283s, according to the manual, looks like compression ratio (8.5 on LD, 8.0 on HD), camshaft timing, and the oil pan (5 vs 6 quart capacity). It should be noted, there were no 283s in '55-56, and in '57 it was only available in 2 ton and larger in trucks, US pickups and 1.5 tons didn't get them until '58.
Bill Burmeister
LONGBOX55 #705542 12/22/2010 12:56 PM
There was a quadjet carb available, did it matter which engine option or was the carb it's own option?
Is interesting because there were 2 different engine colors, for the HD vs LD.
GMCAMARO #705567 12/22/2010 3:43 PM
I don't think that the Quadrajet came out until the 60's. The 4 barrel on the 1957 283 was probably a Carter. There was also a dual 4 barrel and fuel injection option for the cars only.
SimS
SimS #705591 12/22/2010 4:39 PM
the early 4 brl was a rochester 4gc
ron
padresag #705665 12/22/2010 10:25 PM
ron
Was the 4 barrel a separate option or was it part of the HD engine?
GMCAMARO #705671 12/22/2010 10:42 PM
the Roch was optional on all V8s, car [4GC] and truck [4G] ... the shop manual is an excellent resource for anyone with an old truck curious about details, it covers all the bases wink
GMCAMARO #705687 12/23/2010 12:28 AM
I beleive a 283 with 4 barrel came with a different cam and heads and distributor also.
chevyb #705824 12/23/2010 1:36 PM
I think the 4 barrel option was called "Power Pack". Jeez the 50+ year ago memories are fading fast. I think the heads were something different for sure. As a street racing kids in the 60's we were always looking at the casting marks in the front of the heads to determine the "hot setup". I think this was the case for cars. I don't know if the trucks got the "power pack" stuff.
SimS
SimS #706002 12/24/2010 3:19 AM
Depending on the year, the Power Pack option could be either a singe 4bbl or dual 4bbls, with special heads and camshaft. To my knowlege, there was no Power Pack type option for trucks, there was a 4bbl option on the Taskmaster 283, which would make it a Super Taskmaster. That engine was only found in 2 ton and larger trucks.
Bill Burmeister
