0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 35 New Guy | | New Guy Joined: Dec 2010 Posts: 35 | This question is for 55 series 2 3100. The pins in my door hinges are very loose. Getting them off the doors is pretty strait forward. In order to remove them from the cab section does the front fender have to be removed? I can get the hinge off, but not sure it will go back on without removing the fender? Any and all advice appreciated. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | depends on the condition - if the captive nut behind the center bolts are rotten you'll be taking the fender off to replace the nuts, and the hinge pockets as well - if the bolts come out easily you're likely OK .... and lucky  Bill | | |
