| | | Forums66 Topics128,078 Posts1,056,021 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Did they have open drivelines?
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Oct 2010 Posts: 6 New Guy | | New Guy Joined: Oct 2010 Posts: 6 |
1955 5-Window First Series Chevy 1996 SVT Mystic Cobra 2010 Silverado LTZ Crew Cab
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 1/2 tons? As above.
3600 and above have open drive-lines in 1954 and 1955-1st.
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Sorry. I was thinking of the 1/2 tons. So. If a person was lucky enough to find a 55.1 rear - it would be a 'no weld' simple replacement for a 47-53 rear and give the open driveline.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | If you have the springs to go with it, it will bolt right up. The springs on your truck have the mounting hole too far forward. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I need to ask a friend about the rear out of a 55.1 GMC 1/2 ton. Maybe he will have it for sale.
