| | | Forums66 Topics128,114 Posts1,056,287 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 423 'Bolter | | 'Bolter Joined: May 2006 Posts: 423 | The grill on my 53 half-ton has a nice little opening for a handcrank. The end of the crankshaft has a fitting to accept a handcrank. I have seen handcranks for sale, so I know they were available. What I can't figure out is how the handcrank can work when the bottom of the radiator sits most stubbornly between the grill opening and the end of the crank. Are these fittings leftover from an earlier model on which the radiatior was mounted higher? Is the handcrank meant to be used only in the shop when the radiator is removed? Not that I would wish to handcrank a 216, but why the sort of half-option? It may not be the easy way, but it is the Cowboy Way - Ranger Doug Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri 1953 Chevy 3100 1960 Volvo PV 544 1941 Chevrolet Special Deluxe | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I can still remember when the 53 models were in the show room. I never remember seeing anything automotive of that vintage being cranked. Stationary engines were still hand cranked, but they had magnetos. I have never heard a credible reason for the opening in front and a front pulley that would accept a crank and then having the radiator in the way. | | | | | Joined: Nov 2000 Posts: 1,969 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,969 | I don't know the last year it was actually possible to hand crank a Chevy truck with the radiator in place; 1950 maybe. I know my 50 3600 with the original... everything has a notch in the bottom center of the radiator for crank clearance. Here's a good discussion from awhile back with a link to Denny's pictures of the crank and bracket. Like you I suppose the grille and HB/pulley are carryovers. If you ever visit youtube there are a few vidoes of hand cranking 216's. In fact there are lots of 216 Chevy stuff on there.
Professional Novice
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | here's the videos one of our stovebolters put up Bill | | | | | Joined: Feb 2008 Posts: 320 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2008 Posts: 320 | My 51 has a hand crank that the PO used routinely. Though I've never had the opportunity to try; he says it was really quite easy. | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | On my '53, the fan is in the way of the crank. | | | | | Joined: May 2006 Posts: 423 'Bolter | | 'Bolter Joined: May 2006 Posts: 423 | Hey 1953, just the fan, not the rad? It may not be the easy way, but it is the Cowboy Way - Ranger Doug Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri 1953 Chevy 3100 1960 Volvo PV 544 1941 Chevrolet Special Deluxe | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | My 52-3100 can be hand cranked I built a end that fits the front of the harmonic balancer out of a 1/2 inch socket than I put a 12 inch extention and a rachet on it I use it when I adjust the points or the valves makes it easy to turn the engine over so I can get it right where I need to also now in the winter I'll turn the engine over 1/2 a turn once every couple of weeks.
Pete | | | | | Joined: Apr 2010 Posts: 474 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 474 | 1952 is the last year of the engine hand crank.The 1953 hand some of the parts used on them until they were used up.I'm not 100% on this but from my 25 years experience this is what I've seen. | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Hey 1953, just the fan, not the rad? My rad is not in the way, but I have a 261 engine instead of the correct 235. I think the water pump is in a different position so the fan is slightly lower. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If your 1947-53 truck has the harmonic balancer that has the fittings on the front for the crank-rod, you should be able to hand crank it. Some 1953 models and all 1954 and later models had a flat "face" on the front of the harmonic balancer and the crank would not work. Also, the 1954 and later grills would not allow the crank-rod to reach the balancer, even if an older-style balancer was/is used.
| | | | | Joined: May 2006 Posts: 423 'Bolter | | 'Bolter Joined: May 2006 Posts: 423 | There is no way a crank-rod can be inserted into the harmonic balancer of my '53 without drilling a hole through the radiator. I did change the radiator a few years back, but the old one was about the same size and was mounted the same. I would tend to believe 53 panel, and accept that 52 was the last year hand-cranking was possible. It may not be the easy way, but it is the Cowboy Way - Ranger Doug Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri 1953 Chevy 3100 1960 Volvo PV 544 1941 Chevrolet Special Deluxe | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Jim Carter shows the hand crank as being usable from 32-52 trucks.
Even if some 1953 trucks came with the old style harmonic balancer, something else must have changed that year. If anyone has used a hand crank on a 47-52 truck, how did the crank get through the radiator (was there a hump/opening in the base of the radiator prior to 1953)?
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Here we go again, can’t really go by what the books say can we. My ‘54 cooling system is the original one. The numbers match, the year, it’s a 54C R-11 Harrison with the right part number. The original owner who bought it new in ‘54 was over last Monday to look at the truck and we talked about what was done to the truck over the years. So I’m 100% sure that the original radiator in the picture is the one that came in the truck in the spring of 1954, the new one is from US Radiator: http://www.pbase.com/dennygraham/image/131160297/large Even though the grill was not punched out for a hand crank and the balancer does not have a dog for the crank, the radiator lower tank was still indented for crank clearance in ’54. Harrison must have needed to use up the surplus lower tanks. All of the earlier AD’s (pre 1954) that I’ve seen with the correct factory installed radiators have had the radiators with the indented lower tanks. Denny Graham Sandwich, IL
Denny G Sandwich, IL
