8 members (J Lucas, klhansen, Tronman, electors, 78buckshot, cmayna, JW51, 1 invisible),
73
Mod | | | Forums66 Topics128,042 Posts1,055,497 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 83 | The driver's side door on my '41 pickup is drooping as evidenced by the wear in this photo of the door guide (not sure of the correct name for the part). I'm looking for information or advice on the proper way to adjust door fitment on my truck. Thanks. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I've not seen a '41 but it's lost likely pretty similar to my '38. All door fitment adjustment except one in my '38 is controlled at the hinges. The one not adjusted at the hinges is how far the door closes which is adjusted at the striker. You may have wear issues if the door is drooping. That could be as simple as replacing a hinge pin or as complex as replacing or rebuilding the hinge. Good luck with your project.
| | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | My 4t6 is slightly worn like yours. Did you change the pins? That may help. You can also "massage" with a 2x4 and pry and close or push and shove. Hope this helps. Have fun and good luck Dan | | | | | Joined: Nov 2010 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 83 | Thanks for the replies. The truck is new to me, so I haven't changed or adjusted anything yet. I'm disassembling it for restoration, and today I took the door off. The hinge pins were very tight and didn't show any wear. When I reassemble after painting I'll try to tweak the hinges and see if that helps. Any idea where I could get a replacement part for the one that is worn so badly? I don't see that part in any of the catalogs. The passenger door, by the way, is just fine. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | it'd be a really good idea to get that door working right before you do any painting, unless you think painting it twice would be fun  there should be slight adjustment of the door via shifting the hinge bolts a bit, both on the pillar and in the door pretty sure you won't find the dovetail reproduced, have to find a good used one, maybe in the parts wanted here, and for a temporary fix, build that one back to shape with braze Bill | | |
