7 members (klhansen, MNSmith, TUTS 59, Peggy M, Cletus1950, 2-Ton, mick53), 65 guests, and 2 robots.
Topics128,174
Posts1,057,047
Members48,458
Could I hane just an old ground(braded)or is a cell dead in my 53 3600. Gage showa charging and normal wile reating after it's wormed up, BUY it's dead when I try a restart.Thsi all happened when I put a new rebuilt carb(rodchester)on last week. Would like to drive the old girl when I take off all the Christmas Lights......
MLT Offline
Are you leaving the bat hooked up when it sits? I had/have a similar problem. I was unhooking the battery after a run, but yesterday the battery was dead anyway. I think my gen is shot, cause the motor dies immediately if the bat is disconnected. I'm going to rewire and reevaluate at that point.
If you are saying the battery will not turn the starter after the battery has gotten a good charge from the generator, it is possible the battery has a bad cell.
How old is battery? If about five years that may just be end of life.
ALSO check water level - they perform better when celltops covered.
Replace with another you have that you KNOW is good before you do anything else. If problems go away you know one of two things
1. Battery was problem
2 You cleaned the gunk off the connectors and now is good - for a while.
Put old one in for a day and confirm.
Dan Bentler
