| | | Forums66 Topics128,187 Posts1,057,311 Members48,468 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 46 | HI there group, I had a guy put a 14 bolt rear end with 8 lug wheels nuts, under my 1 ton truck from a 1973 truck and it is way to wide. From rim monting face to the other one is 67.5 inches long and my orginal one is 62.5 long.
What year and type would work under my truck with a GVW of 8800 Lbs with 41.5 inch center to center leaf springs and an open drive shaft. He but 3.75 gears in it and moved the leaf spring perches.
Is there and 14 bolt that is shorter and closer to my old 62.5 inch length.
Please help. I`m not looking at a 1/2 ton units or anythign from Patrics. They can not help me.
Thanks Gerry
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | | | |
