1 members (porsche), 111 guests, and 1 robot.
Topics128,051
Posts1,055,767
#70186 12/17/2006 1:21 AM
If the back of the six has the same bolt pattern as the sbc why do i need an adapter plate to mount an automatic to the inline six? I.e the 230/250/292 engine? Is it not a direct bolt up? Are the adapter kits for the older 216/ 235 engines only? Some one please advise me on this will you? Thank you in advance.
Have a great dayu.
Slider
Jesus is Love! Never forget the Veteran.
AND God bless Amercia!
3B Offline
Hy sliderinwa, the simple answer is you don't need an adapter to mount an automatic from a V8 engine to the 194, 230, 250, 292 6 cylinder engine series, hope that helps.
That`s what i thought, and hea, Thank you.
Merry Christmas.
Slider
Slider,
Just be sure you get a Chevy automatic trans, GM also produced BOP (Buick/Olds/Pontiac)& Cad transmissions that will not fit a Chevy (without an adapter). However, some of the later ones had a dual bolt pattern bellhousing.
Fred
Also, watch out on the v-6 trannies. The 60 degree v-6 (2.8,3.1,3.4) have still yet a different pattern than 90 degree Chevy and BOP. You'll mainly see these in S 10s.
Bill Burmeister
