BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
| | Forums66 Topics126,777 Posts1,039,282 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Apr 2010 Posts: 24 Wrench Fetcher | Wrench Fetcher Joined: Apr 2010 Posts: 24 | Can the closed knuckle front axle be converted to disc brakes? Thanks! | | | | Joined: Aug 2007 Posts: 462 'Bolter | 'Bolter Joined: Aug 2007 Posts: 462 | It can be done as there was a guy at the napco website that just done it. | | | | Joined: Mar 2009 Posts: 787 'Bolter | 'Bolter Joined: Mar 2009 Posts: 787 | easier to just bolt in a newer frt end with discs already installed (with corresponding ratio). rear axles are not that difficult either which also gives you larger rea drum brakes ron | | |
