| | | Forums66 Topics128,150 Posts1,056,985 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 93 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 93 | Could I hane just an old ground(braded)or is a cell dead in my 53 3600. Gage showa charging and normal wile reating after it's wormed up, BUY it's dead when I try a restart.Thsi all happened when I put a new rebuilt carb(rodchester)on last week. Would like to drive the old girl when I take off all the Christmas Lights...... | | | | | Joined: Nov 2010 Posts: 63 New Guy | | New Guy Joined: Nov 2010 Posts: 63 | Are you leaving the bat hooked up when it sits? I had/have a similar problem. I was unhooking the battery after a run, but yesterday the battery was dead anyway. I think my gen is shot, cause the motor dies immediately if the bat is disconnected. I'm going to rewire and reevaluate at that point. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | If you are saying the battery will not turn the starter after the battery has gotten a good charge from the generator, it is possible the battery has a bad cell. | | | | | Joined: Aug 2009 Posts: 295 Shop Shark | | Shop Shark Joined: Aug 2009 Posts: 295 | How old is battery? If about five years that may just be end of life.
ALSO check water level - they perform better when celltops covered.
Replace with another you have that you KNOW is good before you do anything else. If problems go away you know one of two things 1. Battery was problem 2 You cleaned the gunk off the connectors and now is good - for a while.
Put old one in for a day and confirm.
Dan Bentler | | |
