| | | Forums66 Topics128,012 Posts1,055,315 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 239 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 239 | Hello,
I have a question. Is the valve order from front to back (on a 228)
#1 exhaust #1 intake #2 exaust #2 Intake #3 exhaust #3 intake #4 exhaust #4 intake #5 exhaust #5 intake #6 exhaust #6 intake
OR
#1 exhaust #1 intake #2 exaust #2 Intake #3 exhaust #3 intake #4 intake #4 exhaust #5 intake #5 exhaust #6 intake #6 exhaust
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. -Unknown-
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | #1 exhaust
#1 intake #2 intake
#2 exhaust #3 exhaust
#3 intake #4 intake
#4 exhaust #5 exhaust
#5 intake #6 intake
#6 exhaust | | | | | Joined: Nov 2009 Posts: 239 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 239 | thank-you. I was definitly confused.
| | | | | Joined: Nov 2009 Posts: 239 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 239 | So, when the rocker pushes the valve down, it is closing it, not opening it... correct?
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | the spring keeps the valve closed, the push overcomes the spring pressure .... take a look at the pretty pictures in your shop manual .... you do have one of those?
Bill | | | | | Joined: Nov 2009 Posts: 239 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 239 | Thanks Bill, That's what I needed.
