2 members (VicZ, klhansen), 118 guests, and 3 robots.
Topics128,072
Posts1,055,904
Members48,429
#698640 11/27/2010 4:49 AM
I try to drive my 6400 at least once a week, but when it gets hot (180-200 degrees) it gets a really sloppy idle. The truck runs like new going down the road and even gets good gas mileage. I might rebuild the carb, but here is the question. My rig still has the governor under the carb. Can a vacuum leak develop on this device that might be causing my poor idle? Would it run better without the governor? I drive like an old man, so I'm not really worried about over revving the engine. Any thoughts?
The governor works with velocity and could develop a vacuum leak and lots of them had governors removed. However a 2 speed, hydravac, stuck pcv valve can also cause a vacuum leak. And of course the normal places that can develop a vacuum leak in any engine. You may just have trash in the carb. I would rev it up and put my hand over the carb and try to suck the trash out.
