3 members (TexasA&M48Truck, TUTS 59, Stovebolt48), 62 guests, and 8 robots.
Topics128,021
Posts1,055,348
Members48,420
#683767 10/06/2010 9:47 PM
Z
Z Offline
I hope this is the right forum. I have a shifter box for my 52 chevy 1/2 ton that has a broken spring inside. I have searched and called but I have yet to find anyone who sells the spring. Any help would be highly appreciated. Thanks in advance.
2000 Nissan Frontier, 3.3L (sold)
2006 Chevy Cobalt SS, 2.4L
1952 Chevy 1/2 pickup, 235 c.i. I6
when life speeds up, downshift
You might be able to match it with a hardware store spring.
I tried that with no luck. If you can, find a used box for spare parts or swap yours for a rebuilt one from vendors.
Drew
DrewP #683950 10/07/2010 12:12 PM
Call Mike at Jimmy Carter they have a pile of old trans's He can get one off one of them.
Pete
Are you talking about the spring on the shift box on the column? If so, one end has a hook on it and the other end looks like it is broken. It may not be broken at all. All it does is keep tension on the levers.
Jim carter use to sell those springs brand new years ago.You might try calling them.
Tim
1951 3100 Chevrolet
http://my.opera.com/red58/albums/showpic.dml?album=595633&picture=71230452
Check this guys pics out. This helped me with a problem that I had with a spring that had been installed incorrectly. It drove me nuts for months until I saw this pic, and re-installed it correctly. Yours may not be broken at all.
Here is a diagram of a car shifter mechanism. The truck's assembly has similar parts in similar locations.
Parts for the mechanism at the bottom of the shaft (4.022) are probably not readily available (except as used parts) but parts for the mechanism at the top (inside the shifter arm and support) are available.
Jim Carter sells reconditioned 4.022 assemblies.
