8 members (Guitplayer, 78buckshot, Otto Skorzeny, cmayna, Cletus1950, Southerntruck, 1955 1 Series, Wayne67vert),
99
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,156 Posts1,056,871 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 43 New Guy | | New Guy Joined: Oct 2010 Posts: 43 | being the new guy i guess i asked in the wrong forum..got a 62 gmc with the 305 v6 and a 3speed stick. hooked in is a fluid clutch. I'm wanting to drop my mild street build chevy 350 in it and go as a daily driver/street-rod setup. what all do i need to do? besides engine perches and mounts and a trans rebuild
62' GMC SWB Fleetside
Why can't we just go back to the designs from when cars were unique and didn't all look the same?
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy keilkravec, other than what you have already mentioned, you need a bellhousing from a 1960 - 62 Chevy truck which came from a V8 equipped truck, your "hydraulic" clutch stuff should transfer over to it. Most of the parts for making the conversion could come from a 1960 - 62 Chevy truck with a V8, hope that helps. | | |
