| | | Forums66 Topics128,091 Posts1,056,036 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 85 New Guy | | New Guy Joined: May 2010 Posts: 85 | OK...this is going to end up really good or really bad! Here's the question: I have a 52 1/2ton. I want to do the front disc conversion. Will this work with 16" stock wheels??? I have seen people say that 15" wheels will not work with front disc, but i can't find any info regarding 16" wheels. any advice would be appreciated. I'm waiting in anticipation
Do something! Even if it's wrong!
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | Can't give you a direct answer, but the usual problem is that the rim is too close to the caliper, so bigger is better (14 doesn't clear but 15 does, etc.). | | | | | Joined: May 2010 Posts: 85 New Guy | | New Guy Joined: May 2010 Posts: 85 | so my "guess" is that i would be ok with 16" wheels?
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | |
