1 members (NJC), 62 guests, and 1 robot.
Topics128,089
Posts1,056,004
Members48,430
OK...this is going to end up really good or really bad! Here's the question:
I have a 52 1/2ton. I want to do the front disc conversion. Will this work with 16" stock wheels??? I have seen people say that 15" wheels will not work with front disc, but i can't find any info regarding 16" wheels. any advice would be appreciated. I'm waiting in anticipation headscratch
Do something! Even if it's wrong!
Can't give you a direct answer, but the usual problem is that the rim is too close to the caliper, so bigger is better (14 doesn't clear but 15 does, etc.).
so my "guess" is that i would be ok with 16" wheels?
