0 members (), 160 guests, and 5 robots.
Topics128,149
Posts1,056,818
Members48,456
#69791 12/10/2006 3:20 AM
What say you? I recall reading somewhere that Diesel spec 14W40 oil is actually better for my old engine than the single-viscosity called for in the owner's manual. And, I get it in quantity for other stuff. What say the gearheads?
1951 3800
-hotshoe
#69792 12/10/2006 3:43 AM
I got a lot of advice on here and read all the threads I got rotella 15 40 from shell at canadian tire it has the Apl plus an ingredient in it it was on sale a while back for $11.00 for 4 litres.. Peter Welcome fellow bc er. Do you know where i can get a 1954 bc licence plate ???
#69793 12/10/2006 4:13 AM
20W50 would be better, but the 15-40 is OK. Since all multi-viscosity oils stay at their minimum weight rating all the time, and only lubricate like heavier oils at higher temperatures, the 15-40 is only half as thick as the straight 30 weight the original specifications reccomend. That will result in somewhat lower oil pressure, particularly if the engine in question has some bearing wear. It will probably lubricate OK, but expect to experience lower than usual oil pressure.
