6 members (MickeyP, Hotrod Lincoln, Nick in Manitou, KingG, 2 invisible), 108 guests, and 3 robots.
Topics128,026
Posts1,055,406
Members48,422
#697885 11/24/2010 8:42 PM
any body got any schdrawings of a '48-3post ign.(off-on) switch to a 5 post ign. switch(acc-off-run-start)? Not sure where all the wires go like the coil and acc.
Thanx.
Happy Turkeyday!
Mike
Riding in the Passing Lane
The 5 term. switch has the terms marked on the back of the switch.
1972 Chevy c10 Cheyenne Super
sure has,
but I'm not sure where to put the wires from my new harness.
Switch is marked:
BATT
SOL
IGN
ACC
GND
My wires are marked:
Ign switch power
Ign switch coil
Ign switch acc
Ign switch Gnd
Ign switch start
Thanx for the help!
Mike
Power is red. Comes from the bat or ammeter. Coil is pink. Goes to the coil or resister. Acc. I believe is brown. Goes to fuse box for heater TS & radio, etc. If you have a temp warning light or brake warning light it is connected to the ground. Otherwise it is not used. The start term is a purple wire goes to the solenoid on the starter.
Wrenchbender Ret................YOU are the MAN!
Thank You.
Mike
