Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (Bill Marlow, Otto Skorzeny, baldeagle, EchoBravoSierra, Jon G, Jeff Ogden), 38 guests, and 3 robots.
Topics128,005
Posts1,055,266
Members48,418
#697381 11/23/2010 5:46 AM
I have a 235 six. A friend gave me a remanufactured Rochester B for my truck. The float level was set to specs. The only thing that I replaced on this carb was to add a .055 jet in place of the .051 jet that was in there. I was able to get 19” in vacuum and set the idle at around 650. Everything seemed fine.
It drove real nice around town but I noticed the idle would keep going down at every stop light. A smooth idle but it would get lower and lower. After I got it home I tried to restart it after 10 minutes and it would not start at all. It wasn’t leaking and I didn’t smell gas.
I ended up taking this carb off and putting my old “B” back on. Is it possible that the power piston is sticking or maybe a faulty idle mixture screw? I checked the power piston and it moves freely. All other non carb settings on my truck have been checked. Dwell is around 30 and the timing is set at 10 degrees BTDC.
Thanks for any help.
1956 Chevy 3200, 1/2 Ton, 235 CI
https://photos.app.goo.gl/TQQo1YnFjs3U7xB57
MarkT #697523 11/23/2010 8:20 PM
From your description, it sounds like the idle mixture is too rich. Possible causes of that condition are the idle mixture screw is incorrectly set, or there is internal leakage that affects the idle mixture. Try setting the idle mixture screw a half turn in (lean). If you set the mixture screw for the highest idle vacuum, it is easy to turn the screw out (rich) a half turn or so without affecting the manifold vacuum. Also, if you set the mixture before the engine reached normal operating temperature, you could have the mixture set too rich for the hot idle.
Harvester
Harvester #697535 11/23/2010 9:33 PM
I backed off the idle mixture a bit when I reached a good vacuum reading. I thought that I was in there.
You're probably right. It most likely is running too rich and flooding. I'm used to seeing these Rochesters leak at the gasket when they flood. This one didn't. I need to tinker some more with it to get it right. Thanks Harvester.
MarkT #697563 11/23/2010 10:35 PM
MarkT where did You get the jet?
Pete
Pete52 #697566 11/23/2010 10:44 PM
Pete - A place called Allstate Carbureter. They are located somewhere in NY. They had jets for the B and BV. They are on Ebay. The jet works fine. Sometimes you never know if they are marked correctly.
MarkT #697571 11/23/2010 10:55 PM
-Tom
1950 Chevy 3100 w/ 1956 235
Oilrag #697600 11/24/2010 12:52 AM
Thanks, could not find a carter 2100s so I rebuilt the B that came on the 216 (high top)was in the truck and used the base of the B that came on the 235 power glide engine(early version) that I just put in My truck, somone had drilled the jet on the 235 carb so the truck was running real rich now it's running alittle lean so I'd like to get a few jets and see if I can find the best mix.
Thanks again,Pete
