0 members (),
116
Mod | | | Forums66 Topics128,080 Posts1,055,954 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#69730 12/07/2006 10:35 PM | Joined: Jul 2001 Posts: 3 New Guy | | New Guy Joined: Jul 2001 Posts: 3 | Howdy guys, I got a 1953 Chevy 235 with a cast iron Powerglide on it. I want to replace the drive clutch plates in the transmission case. I got good accumulator, good servo, and the low and reverse bands are good. Is it possible to remove only the transmission case for service? It seems to bolt right to the torque converter housing. Really hate like hell to have to remove the whole %#@$*?! transmission just to work on that section. :mad: Thanks! Babbitpounder | | |
#69731 12/07/2006 11:44 PM | Joined: Jul 2003 Posts: 132 'Bolter | | 'Bolter Joined: Jul 2003 Posts: 132 | It comes out as a unit, sorry. While you have it out it would really be best to do a complete rebuild. If my memory is accurate, the only special tools needed is a method to measure the end play or clearance in the drive train from the front of the main case to the thrust face of a shaft. This requires a selective fit washer to get it right.
You really want to measure this once and set it up right. I distinctly recall R&Ring a 60 cast iron PG 8 times because I tried to use a jury rigged tool to do this measurement. | | |
#69732 12/08/2006 1:56 AM | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | It also a little tricky to make sure the case is lined up properly. GM used to have a jig to take care of this. | | |
