2 members (1955 1 Series, Peggy M), 115 guests, and 2 robots.
Topics128,094
Posts1,056,066
Members48,433
#697143 11/22/2010 7:03 AM
I have had this chop saw for a few years and just had to replaced the blade for the first time.I cut a lot of metal ,no sparks ,cut's metal like butter and doesn't heat the metal .Here's a video of it http://www.vansantent.com/Saws/evolution_saw_video.htm
Stovebolt Gallery
1952 Chevy 3100
1953 Chevy 4400
1965 Nova
Pics on Photobucket
Man that is amazing..how long do the blades last? Looks way better than my abrasive one.
Yeah that's not a bad blade to have if you’re doing a lot of fabricating. The saw it self is just a woodworking chop, the blade will work on any brand chop saw. Evolution also has a compound version for about a hundred more and that feature would really come in handy if you were fabricating frames, suspension, roll bars etc., where you needed different angles.
Those blades run just under $100 and they claim they will make 750 cuts in 2" box tubing.
Those blades came out a decade or so ago, I've used them mounted on a Skill saw also, scared the bejeebers out of me the first time. But they will cut thru 1/4" alum plate like it was butter. Then again I've cut the same aluminum plate with a carbide blade mounted in a Delta table saw, you just had to be careful feeding it so you didn't chip the carbide.
I never tried cutting steel plate or solid bar stock with those metal-cutting blades. I don't imagine they would last very long cutting plate or bar stock or any heavy steel as far as that goes with out a coolant. The cut shop where I worked had an industrial strength chop saw dedicated to cutting bar stock but it was set up with coolant.
If you have a chop saw for your wood working then just buy the blade for $100 and don't try cutting anything real heavy in it. But it would work great for your tubing projects. At home I would still stick with the horizontal band saw for solid stock.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
I picked up one of the Craftsman Dual-cut saws a few years back, looks like a 6" angle grinder. Very similar to these is it uses 2 counter rotating blades. It's LOUD, & blows chips all over the place, but chops body panels like you were cutting formica. Leaves smooth edges and no heat warping, it's a dream for doing large body panels, esp. if you're chopping donor parts off a wreck. They have a wax lubricant that can be used for cutting softer materials like aluminum to prevent clogging the teeth.
1956 GMC 370 dump " 'Tater "
1970 VW Volksrod "the Black Bomber"
2007 Chevy Avalanche
2020 Jeep Cherokee Trailhawk,
2005 Harley Davidson FLHTCUI
I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things.
But thats just MY opinion!
:P
Moderated by  MNSmith
