| | | Forums66 Topics128,091 Posts1,056,038 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 474 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 474 | I have had this chop saw for a few years and just had to replaced the blade for the first time.I cut a lot of metal ,no sparks ,cut's metal like butter and doesn't heat the metal .Here's a video of it http://www.vansantent.com/Saws/evolution_saw_video.htm | | | | | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | Man that is amazing..how long do the blades last? Looks way better than my abrasive one. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yeah that's not a bad blade to have if you’re doing a lot of fabricating. The saw it self is just a woodworking chop, the blade will work on any brand chop saw. Evolution also has a compound version for about a hundred more and that feature would really come in handy if you were fabricating frames, suspension, roll bars etc., where you needed different angles. Those blades run just under $100 and they claim they will make 750 cuts in 2" box tubing. Those blades came out a decade or so ago, I've used them mounted on a Skill saw also, scared the bejeebers out of me the first time. But they will cut thru 1/4" alum plate like it was butter. Then again I've cut the same aluminum plate with a carbide blade mounted in a Delta table saw, you just had to be careful feeding it so you didn't chip the carbide. I never tried cutting steel plate or solid bar stock with those metal-cutting blades. I don't imagine they would last very long cutting plate or bar stock or any heavy steel as far as that goes with out a coolant. The cut shop where I worked had an industrial strength chop saw dedicated to cutting bar stock but it was set up with coolant. If you have a chop saw for your wood working then just buy the blade for $100 and don't try cutting anything real heavy in it. But it would work great for your tubing projects. At home I would still stick with the horizontal band saw for solid stock.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Dec 2006 Posts: 720 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 720 | I picked up one of the Craftsman Dual-cut saws a few years back, looks like a 6" angle grinder. Very similar to these is it uses 2 counter rotating blades. It's LOUD, & blows chips all over the place, but chops body panels like you were cutting formica. Leaves smooth edges and no heat warping, it's a dream for doing large body panels, esp. if you're chopping donor parts off a wreck. They have a wax lubricant that can be used for cutting softer materials like aluminum to prevent clogging the teeth. 1956 GMC 370 dump " 'Tater "1970 VW Volksrod "the Black Bomber" 2007 Chevy Avalanche 2020 Jeep Cherokee Trailhawk, 2005 Harley Davidson FLHTCUI I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things. But thats just MY opinion! :P
