4 members (UtahYork, cmayna, Otto Skorzeny, Bucker), 111 guests, and 0 robots.
Topics128,162
Posts1,056,916
Members48,458
Just picked up a 1949 suburban on ebay the seller sent me some other pics nto listed inthe auction i noticed the dash is broken where the steering column mounts this must be a commen ad truck problem?? i had a parts truck before was broken same spot is there a repair panel made or just get to fabbing and welding ??
pic http://i89.photobucket.com/albums/k237/bigtony55/Untitled-17.jpg
Stovebolt CHEVROLET
1949 Chevrolet Suburban
Non stovebolt CHEVROLET
1958 Impala Convertible
1963 Impala Convertible
MY 1949 SUBURBAN
Maybe both trucks had been in an accident (wherein the frame got pushed, pushing the steering column up/out/in)?
Can't recall seeing anyone selling repair panels.
I'd expect that might be "common" on panel/burb bodies due to the steering column being fixed to the frame - as the body mounts age and settle to allow wracking that would stress that mount point .... that's part of why the panel/burb bodies have different bracing than the pickups in the front and front anti-sway bars .... at least on the later series, the AD's may have been the 'learning experience'
I know they sell after market dashs i also have one that was cut out of a donor truck is there any tricks to putting them in or is it cut wisley re line up and start welding? my dash was alot more jacked up than i thought when i posted the first pic it was before i had it here
http://i89.photobucket.com/albums/k237/bigtony55/100_4918.jpg
http://i89.photobucket.com/albums/k237/bigtony55/100_4919.jpg
Stovebolt CHEVROLET
MY 1949 SUBURBAN
The dash itself is spot welded in to the cab. I would think it would be very complicated to remove.
If the cracking is around where the steering column mounts, I would say that is fairly common. As the front cab structure starts to fail, the cab tries to settle. It then pivots downwards with the pivot axis being the rear shackle system. At the same time the steering column get pushed lower and it is pivoting on the box in the frame at the front. The two paths appose each other and the loser is the metal on the dash near the column mount. I had to weld mine up there too.
What kind of car do you have on the rotisserie there?
1951 1 Ton Completed
Where?
Stovebolt CHEVROLET
MY 1949 SUBURBAN
I was looking at one of your other photos and there is a car on a rotisserie.
Oh weird i thought i had my photobucket marked private LOL buy thats my/my daughters 1963 impala convertible
Stovebolt CHEVROLET
MY 1949 SUBURBAN
bigtony55,
sorry, I didn't mean to be probing. Sometimes folks post links which don't quite work and with a little patience one can find the intended photo. In your case I thought maybe I would see some more of your Suburban as I think they are really cool. If you take your original photo and change the number, you will link to the car.
