6 members (Bill Hanlon, fonz8261, Shaffer's1950, tclederman, Hotrod Lincoln, Charles in CA), 70 guests, and 3 robots.
Topics128,087
Posts1,056,376
Members48,442
#696593 11/20/2010 3:21 PM
is there a auto transmision that would bolt directly 2 my 292, with little or no complicated modifications, ( can find at local junkyard)
speak softly and carry the biggest wrench
Anything that bolts to a small block chevy will bolt to your 292.
Steve
'49 3800
'52 3600
'57 3100
thanks, i thought that might be the case, but first build, first at everything but lovin every second of it
do you have any suggestions?
J M Offline
A TH350 is a really good transmission, the only problem is that it does not have overdrive. You will also need to change the flywheel to a flex plate. There will be other things, like the shift linkage and a cooler on or in front of the radiator.
good luck.
Jim
will that be a suitbale tranny for cruising around town, and maybe some longer trips??
IS IT WORTH THE TIME? AND SHOULD IT BE A SHORT OR LONG
Riding in the Passing Lane
It depends on what your rear end ratio is & tire diameter. I'm not sure what year you have but most of these old trucks are geared pretty low. A 350 trans. will not give you anymore highway speed then a manual trans. You might want to look at a 700R4 trans.
1972 Chevy c10 Cheyenne Super
wrentchbender, i have a 63 C10 with a 292 in it, ill have too see about the gear ratio. Thanks for the comment
