9 members (klhansen, rfs56trk, Bill Hanlon, 1955 1 Series, DHedrick, Otto Skorzeny, 39Master85, greenie-reddy, Peggy M),
136
Mod | | | Forums66 Topics128,087 Posts1,056,399 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 26 | is there a auto transmision that would bolt directly 2 my 292, with little or no complicated modifications, ( can find at local junkyard)
speak softly and carry the biggest wrench
| | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | Anything that bolts to a small block chevy will bolt to your 292. | | | | | Joined: Oct 2010 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 26 | thanks, i thought that might be the case, but first build, first at everything but lovin every second of it
| | | | | Joined: Oct 2010 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 26 | do you have any suggestions?
| | | | | Joined: Nov 2006 Posts: 247 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 247 | A TH350 is a really good transmission, the only problem is that it does not have overdrive. You will also need to change the flywheel to a flex plate. There will be other things, like the shift linkage and a cooler on or in front of the radiator. good luck. Jim | | | | | Joined: Oct 2010 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 26 | will that be a suitbale tranny for cruising around town, and maybe some longer trips??
| | | | | Joined: Oct 2010 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 26 | IS IT WORTH THE TIME? AND SHOULD IT BE A SHORT OR LONG
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | will that be a suitbale tranny for cruising around town, and maybe some longer trips?? It depends on what your rear end ratio is & tire diameter. I'm not sure what year you have but most of these old trucks are geared pretty low. A 350 trans. will not give you anymore highway speed then a manual trans. You might want to look at a 700R4 trans. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2010 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 26 | wrentchbender, i have a 63 C10 with a 292 in it, ill have too see about the gear ratio. Thanks for the comment
