| | | Forums66 Topics128,022 Posts1,055,352 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 118 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 118 | I did a compresion test on my 283 today. the front six looked pretty good. they all hit 140+ and worked there way up a little higher. Number 7 started at 130 and worke up to about 150. Number 8 started at about 90 and worked up to about 125. I put a couple of shots of oil in the number 8 and did not get a change. I did do the test with the engine cold because I have the carb off and Im waiting on some parts but I wanted to change out the plugs and get ir ready while I was waiting. should I be concerned. I don't put alot of miles on it so I was planing to run her till she wouldn't run any more but I need it to run ok in the process. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You have a weak valve on #8 cyl. but like you say you just want to run it a while, it will run a long time like that. If it is an auto trans. you will get a shake at idle in drive. With a manual trans. you probably will hardly notice it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2009 Posts: 118 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 118 | Thanks. thats what I thought. Maybe I will rebuild the heads next summer when its to hot to ride in the darn thing anyway. | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | | | |
