4 members (Rich'sToys, Hotrod Lincoln, TooMany2count, 1 invisible), 130 guests, and 6 robots.
Topics128,021
Posts1,055,354
Members48,420
#695847 11/17/2010 11:52 PM
I did a compresion test on my 283 today. the front six looked pretty good. they all hit 140+ and worked there way up a little higher. Number 7 started at 130 and worke up to about 150. Number 8 started at about 90 and worked up to about 125. I put a couple of shots of oil in the number 8 and did not get a change. I did do the test with the engine cold because I have the carb off and Im waiting on some parts but I wanted to change out the plugs and get ir ready while I was waiting. should I be concerned. I don't put alot of miles on it so I was planing to run her till she wouldn't run any more but I need it to run ok in the process.
61nate #695862 11/18/2010 12:41 AM
Riding in the Passing Lane
You have a weak valve on #8 cyl. but like you say you just want to run it a while, it will run a long time like that. If it is an auto trans. you will get a shake at idle in drive. With a manual trans. you probably will hardly notice it.
1972 Chevy c10 Cheyenne Super
Thanks. thats what I thought. Maybe I will rebuild the heads next summer when its to hot to ride in the darn thing anyway.
61nate #695922 11/18/2010 3:46 AM
Why do you valve?
