1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | I was rummaging through a box of old stuff I had and found this stick of body lead from the GMC plant in Oshawa - I think it is from the 50's - my uncles worked up there leading seams - using whale oil and wooden paddles. GMC lead stick Maybe a collectors item now.  | | | | | Joined: Mar 2005 Posts: 284 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 284 | I learned how to lead in the 70's. I never did use it when I went to work in the body shop. | | |
