0 members (), 170 guests, and 3 robots.
Topics128,081
Posts1,056,078
Members48,434
#692698 11/07/2010 3:54 AM
My vac two speed is bad anyone change to eletric? new parts out there or need to find used? can the diaphram just be replaced? I know they are obsolete> Thanks tony
You should be able to find a replacement diaphragm. I'm not sure of a source though...but I do know people have replaced them. It would definitely be much easier to fix what you have then to try and figure out how to change it over to electric. If you really don't want to use the vacuum you could always make up some linkage/cable to operate the rear end instead of the vacuum can.
1946 Chevy OS 1.5ton, 1955 GMC 3100, along with other various IH,Ford,Nash,MGB,.....
3B Offline
Hy crockbuyer, the o.e.m. p/n for the diaphragm is 3847058 which is Bendix p/n 374451. The diaphragm assembly is o.e.m. p/n 3874330 which is Bendix 2504299, I hope that helps you to find one or the other.
3B #693419 11/09/2010 4:34 PM
3B Offline
Hy crockbuyer, where have you gone? I did some more searching yesturday, I found a supplier, "GM Parts Giant" 1-877-788-1675, they say they have diaphragm p/n 3847058 $31.12 plus shipping, hope that helps.
3B #694953 11/15/2010 2:48 AM
thanks for the info!!!!!
