8 members (Leo, wvstovebolt, SuperSport, Flint48, Red75bronco, 78buckshot, TUTS 59, 1 invisible),
85
Mod | | | Forums66 Topics128,129 Posts1,056,697 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 39 New Guy | | New Guy Joined: Jun 2012 Posts: 39 | Great thread. Now the $64K question - where can I get a replacement spring? (other than the bone yard).
Rick in San Diego (...er, Jackson) '66 FleetsideOl' Car Guys"I was born in the back seat of a Yellow Cab in a hospital loading zone and with the meter still running. I emerged needing a shave and shouted 'Times Square, and step on it!'" - Tom Waits
| | | | | Joined: Sep 2011 Posts: 255 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 255 | Jim Carter has 'em. Brand spankin' new! | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yep,,,that orta cover it Tim.
Denny G
Denny G Sandwich, IL
| | | | | Joined: Jun 2012 Posts: 39 New Guy | | New Guy Joined: Jun 2012 Posts: 39 | Thanks! (he said sheepishly)
| | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Tread revival… anyway, I am in the process of restoring my exhaust manifold. My heat riser shaft was almost worn all the way through. I cut it apart to get it out of the manifold and will make another shaft…that's the easy part. What I am not sure how to handle is the enlarged holes in the manifold. It seems there may have been bushings originally, but not sure. Anyone have any suggestions on what to about the holes in the manifold: bushings, etc. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Tread revival… anyway, I am in the process of restoring my exhaust manifold. My heat riser shaft was almost worn all the way through. I cut it apart to get it out of the manifold and will make another shaft…that's the easy part. What I am not sure how to handle is the enlarged holes in the manifold. It seems there may have been bushings originally, but not sure. Anyone have any suggestions on what to about the holes in the manifold: bushings, etc. chevs of the 40's offers an oversized shaft ...click... | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Thanks, I found that eventually. Sorry about the blank post...happens when I use the Ipad (and I forget). Unfortunately, the Chevy of the 40s website does not say how much oversized and so I cannot ensure that the holes in the exhaust manifold are not still worn too large. May just give it a try or look for brass bushing that I can insert and drill out to a shaft size I make on my own.
Originally, did the manifolds have bushings installed? | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | I'll bet if you phone them and ask, they'll tell you how big the shaft is. | | | | | Joined: Feb 2019 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2019 Posts: 23 | Somebody decided to remove my heat riser valve shaft, flap, spring and weight. They plugged the holes with a bolt, washer, and nut on both sides.
I would like to put my 216 back the way it came from the factory...
It looks like I can get a new shaft and spring.
Does anybody have a flap and weight I could buy?
Thanks!
| | | | | Joined: Feb 2004 Posts: 29,838 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,838 | I make those parts out of stainless steel, and use a stainless disc with the hole for the shaft a little off-center for a counterweight. With a little creative tinkrting with an angle grinder, you can shape the weight for the proper opening force on the flap as the spring heats up. The stainless flap, shaft, and counterweight will still be in good shape when your grandkids inherit the truck in a few decades. Jerry
| | | | | Joined: Feb 2019 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2019 Posts: 23 | Hi Jerry, would you please make me a disk and a weight? I would gladly pay you for your effort! I think I would be more inclined to do it if I had a sample of the shape and thickness. I am missing all of the parts!
I could even draw it in Solidworks cad and have it made by machine! | | | | | Joined: Feb 2004 Posts: 29,838 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,838 | Like I used to tell my students when I taught auto mechanics- - - - - -"It takes a smart student to get the instructor to do all the work"! I throw out ideas on this forum, and even assist with some of the technical stuff, but it's up to younger guys to jump into action and get the work done. After 60-something years in the automotive business, I've become the crochety old geezer sitting by the stove and making snide remarks while the young sprouts get busy! Cardboard for pattern material, an X-Acto knife and a pair of scissors, and an angle grinder and a good set of files work as well, or sometimes better than CNC equipment! LOL! Jerry
| | | | | Joined: Feb 2019 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2019 Posts: 23 | I found one on eBay. As soon as it arrives, I will use it as a sample and create a brand new one out of stainless! | | |
