1 members (JW51), 96 guests, and 0 robots.
Topics128,050
Posts1,055,643
#692843 11/07/2010 8:09 PM
dwm
Offline
Are the drive shafts in a 1963 short box the same length in both automatic and standard transmission trucks?
dwm #693492 11/09/2010 10:00 PM
3B Offline
Hy dwm, according to my Canadian parts book the front driveshaft for the three speed heavy duty, and the four speed is the same p/n 3768971 63 1/4" long, the front shaft for the three speed standard duty trans, and Powerglide is the same p/n 3830486 58 45/64" long, hope that helps.
3B #693688 11/10/2010 3:12 PM
dwm
Offline
Thanks for the info, but isn't the short box a single drive shaft,not two?
dwm #693732 11/10/2010 6:44 PM
dwm
Offline
Maybe I'm not giving enough information. My truck is a 1963 1/2 ton shortbox fleetside with a 283 engine and a 3 speed manual trans.
dwm #693776 11/10/2010 9:47 PM
3B Offline
Hy dwm, I rechecked my Canadian book, there is only one wheelbase listed for 1/2 tons 115", the drive shaft info I provided is correct for a Canadian 1/2 ton, possibly American trucks are different.
3B #694579 11/13/2010 4:57 PM
I doubt they are the same. The standard 3 speed trans is about 15" long.(Measured from the bellhousing mount to the end of the tailshaft). The powerglide is probably about 5" longer.
Fred
rfs56trk #695195 11/15/2010 9:58 PM
dwm
Offline
OK. Was the 3 speed manual driveshaft a single piece or double shaft with carrier bearing?
