| | | Forums66 Topics128,050 Posts1,055,646 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 32 | Are the drive shafts in a 1963 short box the same length in both automatic and standard transmission trucks? | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy dwm, according to my Canadian parts book the front driveshaft for the three speed heavy duty, and the four speed is the same p/n 3768971 63 1/4" long, the front shaft for the three speed standard duty trans, and Powerglide is the same p/n 3830486 58 45/64" long, hope that helps. | | | | | Joined: Mar 2010 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 32 | Thanks for the info, but isn't the short box a single drive shaft,not two? | | | | | Joined: Mar 2010 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 32 | Maybe I'm not giving enough information. My truck is a 1963 1/2 ton shortbox fleetside with a 283 engine and a 3 speed manual trans. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy dwm, I rechecked my Canadian book, there is only one wheelbase listed for 1/2 tons 115", the drive shaft info I provided is correct for a Canadian 1/2 ton, possibly American trucks are different. | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | I doubt they are the same. The standard 3 speed trans is about 15" long.(Measured from the bellhousing mount to the end of the tailshaft). The powerglide is probably about 5" longer. Fred
| | | | | Joined: Mar 2010 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 32 | OK. Was the 3 speed manual driveshaft a single piece or double shaft with carrier bearing? | | |
