4 members (2-Ton, Ponchogl, Robert Crandall, 1 invisible), 89 guests, and 2 robots.
Topics128,037
Posts1,055,463
Members48,422
#692911 11/07/2010 11:58 PM
I have two engines:
Casting #s from one (3835911) are for a '54 first series 235 with Power Glide.
Casting #s from the other (3733949) are for a '55 first series 235 without the Power Glide.
Is there a difference between the '54 and the '55 235s?
What is the difference between the Power Glide 235 and the non Power Glide 235?
Both of these engines have been rebuilt. Which one would you use?
twotone #692922 11/08/2010 12:30 AM
The Powerglide 235 would have hydraulic lifters.
All truck 235s had mechanical lifters.
I'd use the truck engine (in a truck).
I
I Offline
Wouldn't the hydraulic lifter engine be quietier and need less adjusting?
ia49 #692949 11/08/2010 1:52 AM
Yes, usually. That is why some people prefer hydraulic lifters.
Is it true that a Powerglide 235 has more horsepower?
Tim-
Any particular reason?
Dave
The Blue Funk: a '51 3100 4 OTF with a '57 235
More pix on Photobucket
The 1954 PG engine was rated at 125 HP and the truck engine at 112 HP. The PG engine cam provides about 30% more valve lift. More engine spec data is in Resto-Packs for the Powerglide engine and the truck 235.
Hoyt
hoyt #693164 11/08/2010 8:12 PM
The difference in actually driving your truck with each engine would be hardly noticeable. As said above, if you don't want to adjust valves put the powerglide motor in.
Quote
tclederman, if the power glide 235 has more horsepower and has hydraulic lifters, why would you run the 'truck' engine instead? I don’t question your infinite wisdom, but I do wonder what makes the one more suited to truck use when ‘on paper’ the ‘car(?)’ 235 makes more sense to a novice. Teach me!
twotone #693423 11/09/2010 4:47 PM
It's got nothing to do with any wisdom. It's just my opinion (and the fact that I am, sadly, sort of a truck "purest").
It's got nothing to do with what is more suited for a truck, unless you plan on high revving the engine (as GM might have been thinking when it put mechanical lifters in its Corvette "high hp" 235, which came with a Powerglide transmission).
That's good enough for me. I kind of like that sewing machine sound of mechanical lifters anyway smile
twotone #693597 11/10/2010 4:15 AM
Originally Posted by twotone
. . . . I kind of like that sewing machine sound of mechanical lifters anyway smile
I was going to post that but I thought you might think I was joking.
