1 members (baldeagle), 42 guests, and 2 robots.
Topics128,037
Posts1,055,466
Members48,424
I have a wierd electrical issue. My brake lights are out, but my turn signals aren't. When I turn on my headlamps, my rear lamps don't turn on. What do you think it is?
1958 Apache Shortbed Fleetside
light switch or loose connection there, brake/tail lights get power from there - the flasher gets power from the ign sw or the fuse panel, if the signals work that'd show the wiring from the dash to the rear is good, and [maybe] the grounds on the lights .... check for power at the T[tail, black wire] and S[stop, orange wire] terminals on the switch
I did have the instrument cluster out today. I could have knocked off the connecting wire. I'll check that. Thanks!
problem solved. Was a bad connector.
