1 members (klhansen),
92
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,741 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 14 Apprentice | | Apprentice Joined: Jan 2009 Posts: 14 | I have a '51 Chevy Truck with a '61 235. It has been running great the past few years. Last night I went to put it in the garage, and upon start up there was a very loud, rapid knocking sound. I shut it down immediately. It was kind of a hollow sound; very rapid. Can anyone Help with a suggestion?
1951 Chevy 3100
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | pull valve cover and check rockers/adjustment, ignition off crank it and watch'em move, properly or not
Bill | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | X2 - could be 1 stuck valve, but watch your oil pressure!! | | | | | Joined: Jan 2009 Posts: 14 Apprentice | | Apprentice Joined: Jan 2009 Posts: 14 | Thank you for your Help so far. Since I am not a mechanic, I had an in-law who is come over this morning and listen to it. I started it up and the knocking stopped after 4-5 seconds. It initially ran rough, but smoothed out after the sound stopped. He said that his opinion was that the problem was a bearing located on the bottom of the piston rod, which connects to the crank shaft. However, to me the rockers and/or stuck valves also makes sense. And the rough running could be due to the carburator/choke combination. Could any of you give me additional help.
1951 Chevy 3100
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | maybe the later engine is a car version with hydraulics and a gummy lifter?
Bill | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If you have a valve sticking open, it will cause a big miss and the push rod will rattle around. They don't usually recover from this but sometimes it does happen. | | |
