3 members (WICruiser, TexasA&M48Truck, Charles in CA), 63 guests, and 2 robots.
Topics128,029
Posts1,055,417
Members48,422
#691907 11/04/2010 12:50 PM
How can you tell or can you if a motor in a 54 3100 pickup is the original motor or if it came out of a car or a truck? I ordered some premade fuel lines and the one from the carb to the fuel pump is about 4" short reaching the fuel pump, the pump is too low. Is the fuel pump in the same location for a car motor or truck motor?
3B Offline
Hy mperk, there will be a number stamped into the machined pad just behind the distributor, there shold be a plate somewhere on the truck that refferences that number. No truck engines that I'm aware of came with hydraulic lifters. All the fuel pump locations for the 216, 235, and 261 engines are the same. Could your fuel line have been designed for the installation of a filter in front of the carb?
3B #692027 11/04/2010 7:48 PM
