| | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 38 New Guy | | New Guy Joined: Nov 2009 Posts: 38 | How can you tell or can you if a motor in a 54 3100 pickup is the original motor or if it came out of a car or a truck? I ordered some premade fuel lines and the one from the carb to the fuel pump is about 4" short reaching the fuel pump, the pump is too low. Is the fuel pump in the same location for a car motor or truck motor? Thanks | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy mperk, there will be a number stamped into the machined pad just behind the distributor, there shold be a plate somewhere on the truck that refferences that number. No truck engines that I'm aware of came with hydraulic lifters. All the fuel pump locations for the 216, 235, and 261 engines are the same. Could your fuel line have been designed for the installation of a filter in front of the carb? | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | | | |
