| | | Forums66 Topics128,014 Posts1,055,332 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 11 New Guy | | New Guy Joined: Aug 2010 Posts: 11 | Actually she's stuck in 2nd. She was always a little funky going from 1st to 2nd but 2nd to third was smooth. Once in awhile 1st to 2nd was smooth. Any hints at what to look for tomorrow? '64 C-10, 230 with 3 on the tree.
Thanks in advance, M
'64 Stepside LWB.
| | | | | Joined: Jun 2010 Posts: 188 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 188 | The transition shift arm on your steering column gets worn out with age. There's 3 arms. Centre one has a small nub on both sides. The nubs get worn and won't slide smoothly into the other shift arms. You can get lucky and just pull the arms back to nuetral position or use a big screwdriver to help pop them back. In some cases you need to get under the truck and tap the arms on the tranny back to nuetral. Make sure your truck can't roll away though. When you get it back to normal the best way to shift from 1-2 is to shift up towards reverse and then down slightly and over and up to 2nd. Takes a little practice but still carry a big screwdriver in the glove box in case you need it. LOL!!! | | | | | Joined: Aug 2010 Posts: 11 New Guy | | New Guy Joined: Aug 2010 Posts: 11 | Mahalo!! She's on a flat surface. And the big screwdriver is in the glovebox. I'll give you a heads up tonight.
Aloha, M
'64 Stepside LWB.
| | | | | Joined: Aug 2010 Posts: 11 New Guy | | New Guy Joined: Aug 2010 Posts: 11 | Everything is good to go now, did what you said but problem would come back, sprayed the linkages down with a degreaser, cleaned everything with a rag and pick then reapplied new grease. She's smooth as silk!!
Mahalo again, M
'64 Stepside LWB.
| | | | | Joined: Jun 2010 Posts: 188 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 188 | Good to see it worked for you. Sorry I should of mentioned the regrease it method too. Keep On Truckin' | | |
