0 members (), 50 guests, and 6 robots.
Topics128,014
Posts1,055,327
Members48,419
#6914 10/12/2004 5:07 PM
Junior Member
Junior Member
I plan on swapping the 6 banger out for a V-8 in my 1966 C20.
Is there any tricks to bolting a Small-Block or Big-Block Chevy up to the original 4 speed on a 66 Chevy Pickup?
Can it be done or am i going to have troubles??
#6915 10/12/2004 6:45 PM
If your 6 banger is a 230 or 250 a small or big block v8 will bolt in with virtually no modifications. You'll only need to find the proper engine mounts to attach to the frame brackets. The frame brackets will stay in the same position they are in with the small 6.
If you have the big 6 (i.e. 292) then you'll have to change the passenger side frame bracket mount. Find one from any 63-72 truck with either a 230,250 or small block v8.
Even with the big block v8 you'll find that you'll still have plenty of room to work under the hood.
-ftyler
#6916 10/12/2004 7:01 PM
Junior Member
Junior Member
Thank you ftyler! Helps alot.
Might have to call on your help again sometime. Thanks.
#6917 10/12/2004 7:51 PM
Sure. Anytime.
I have a 66 c10 that I swapped out a 230 for a 292. From the cab forward is the same as your c20.
-ftyler
