Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
13 members (Ponchogl, mvigo, 46 Texaco, Leo, Gib70, Possum, Deegs53, TUTS 59, RBs36, niobrarafun, 2-Ton, 2 invisible), 556 guests, and 1 robot.
Topics126,776
Posts1,039,277
Members48,100
Most Online2,175
Jul 21st, 2025
#690634 10/31/2010 4:47 AM
Just bought a 1965 3/4 ton 4x4 rolling chassis and would like to know what rear differential it has. Who makes it? It has a third member drop out on the front of the housing and a 10 bolt round cover on the rear of the housing. 8 lug. Also does anyone know off hand what ratios they came with? The front diff. still has the tag attached and it has 4.55 stamped into it. Is this the ratio?
Thanks!
Rear diff is an Eaton HO52, most likely with the 4.56 gear. Options are very limited, there are no aftermarket gearsets for that differential. Using OEM parts, the other choices are the 4.10 from the '68-'72, or the 5.13 from the 1 tons. Your front diff should be a closed knuckle Spicer 44, 4.55 would be the ratio.
Bill Burmeister
Thanks!
I have also heard that it could be an HO72? What is the difference?
HO72 was the 1 ton version of the HO52. 3rd member is the same other than gear ratio, main difference is larger brakes on the HO72.
Bill Burmeister
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.147s Queries: 14 (0.145s) Memory: 0.6018 MB (Peak: 0.6396 MB) Data Comp: Zlib Server Time: 2025-09-22 16:40:10 UTC
Valid HTML 5 and Valid CSS
