| | | Forums66 Topics128,049 Posts1,055,652 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | I’ve just posted for this nut in the swap meet. But it would really help if I can find out if the 1” 20TPI nut used as a drive shaft U joint yoke retaining nut is also used on any later trucks. Maybe then I can find one at my local FLAPS | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | A 1x20 would be extremely fine. Are you sure it's not a 7/8"?
| | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | yup she is definitely a 1" - 20tpi | | | | | Joined: Feb 2004 Posts: 29,767 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,767 | A 1"X20 thread is a Unified National Extra Fine designation, same as 3/4" and 7/8" UNEF. http://en.wikipedia.org/wiki/Unified_Thread_StandardYou'd ask for a 1" UNEF nut, and short of a bolt and nut specialty merchandiser, I doubt that you'll find one. A FLAPS or a hardware store definitely won't have it in stock. Jerry
