4 members (KEVINSKI, DadsFirstPickup, Hanks custodian, Ponchogl), 198 guests, and 1 robot.
Topics128,108
Posts1,056,230
Members48,436
Got a question....I have a SM420 in a '52 frame, still has the torque tube set up. I picked up a serviceable '56 3100 rearend and want to change over the center section in the '52 axle. I kinda remember reading something about being able to swap the output shaft to a '55 2nd and later style SM420. Is this possible or should I find the later trans?
1948 Chevrolet 1-Ton Grain Truck
In the Stovebolt Gallery SOLD
More pix in Photobucket
"A Man & His Truck--It's a Beautiful Thing!"
"You're never 100% ready, you're just next"....Ty Murray
All you need is the rear bearing retainer and yoke from an
open driveline SM420. It's a pretty easy swap.
Steve
'49 3800
'52 3600
'57 3100
Thanks Steve!
You're welcome hawk.
Here are photos of what you need...as mentioned it is a bolt on after you remove your torque tube rear bearing retainer and u-joint. It would also be a good time to replace the rear seal as well.
Steve
'49 3800
'52 3600
'57 3100
You know, it's possible I have that part. Somewhere. Removed it when I installed a gearvendors. I always tell myself never to throw anything away. You never know. Let me know if you might want that and I'll hunt for it.
orchidskip, I truly appreciate that & I'd be willing to work out something with you if it could be found. No huge rush...I'm headed into winter and wont have a great deal of time to work on it.
Thanks a bunch, Steve, for the pics....extremely helpful for a newb! grin
