7 members (Gray_Ghost, 52Carl, Gdads51, Peggy M, papas52, Otto Skorzeny, baldeagle),
144
Mod | | | Forums66 Topics128,165 Posts1,056,999 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#69029 11/23/2006 3:26 AM | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | im tired of my 89 305 tbi camaro running like crap.is there a mechanic that could diagnose it at a reasonable price?im a good parts replacer.ive replaced so many things on this car with little improvement. | | |
#69030 11/23/2006 4:58 PM | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | if you don,t put it on a machine you are shooting in the dark,,,what is running like crap mean and what have you replaced...doc | | |
#69031 11/24/2006 4:04 AM | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | it pulls like it has about 75 hp.minor backfires starting and sometimes running,bad vibration around one thousand rpm.i replaced fuel filter,egr valve,computer,distributer module,sparkplugs,sparkplug wires,oxigen senser and gutted the cat.ran several bottles of gas additives,took tb off,cleaned passages and squirted out with cleaner,watched the injecters to watch for cone pattern. | | |
#69032 11/24/2006 3:13 PM | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | no info about the fuel pump preasure and flow from what you tell that is where I,d take a look also the map senser might be bad....doc | | |
#69033 11/24/2006 3:24 PM | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | i don't have a guage to check fi fuel pressure,i guess i will buy one.the car has 140000 miles on it .the pump may be weak.also the map senser. | | |
#69034 11/24/2006 3:53 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I have seen more trouble w/fuel pumps than anything else on these cars-it won't set a code, only a scanner will tell you if fuel trim is off. With that many miles I would toss a pump in it-I had a early 90s TBI Cavalier brought to me once, it had been all around & no one could figger it out. Fuel pressure spec'd @14psi, car had 13psi. I guess most guys thought that was OK, but the car wouldn't go over 45mph. Ran perfect otherwise. New pump & it was good to go. Brian | | |
#69035 11/25/2006 2:04 AM | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | only thing is the pumps in the tank and i will have to remove the exhaust to get to it.i checked at pep boys today to get a guage but all they sell now is gadgets and chinese motorcycle type stuff. | | |
