3 members (Peggy M, mick53, kades51), 51 guests, and 9 robots.
Topics128,012
Posts1,055,313
Members48,419
#690111 10/29/2010 5:26 AM
I have heard of self-etching primers and epoxy primers. Problem is I dont know the differance. As I strip mine and do the metal work it may be a year or more b4 final paint. Suggestions?
Brad
brsdb3381 #690143 10/29/2010 10:54 AM
I used epoxy primer, in my opinion witch is based on asking alot of question's,epoxy is the better sealer for layed away party's. Then when your ready you just scuff it off/take the shine off it... and your ready to go with your next step.
Good luck with it.
Len
layback
laybacklenny #690147 10/29/2010 11:59 AM
Use epoxy primer. It isn't porous so no rust and when you're ready for bodywork you can just start working. Etch primer is fine for things like wheels where you're going to just paint over it but you can't use plastic filler over etch primer.
Simplify your life and just use the epoxy primer. It's good for all applications but etch primer isn't.
Voice of experience here.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Czechman #690586 10/31/2010 1:33 AM
Self etching primer has an acid additive instead of hardener, that actually bites into the metal.
Both Epoxy and self etching primer offer excellent corrosion protection. The beauty of epoxy is that body filler can be applied over most brands.
