7 members (Gray_Ghost, Rusty Heaps, Brian Moore, 55shaker, Otto Skorzeny, Hotrod Lincoln, 1 invisible), 85 guests, and 2 robots.
Topics128,028
Posts1,055,414
Members48,422
#689404 10/26/2010 10:32 PM
I bought one of THESE and there is no indication as to which speaker wire is positive and which is negative.
However one wire has a male plug and a female receptacle. The male has no rubber insulation shield but the female does.
Is it possible to figure out negative from positive by the male/female thing?
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Czechman #689414 10/26/2010 11:30 PM
A good guess would be the insulated one is positive.
Cletis #689467 10/27/2010 2:45 AM
Speakers shouldn't be polarity sensative Woody, just pick one.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Cletis #689549 10/27/2010 11:29 AM
That's what I thought but then I thought why would the non-powered positive be shielded? Wouldn't it make more sense to insulate the positive wire on the hot side?
And Denny, I don't know if you're serious or not but every speaker I've ever wired has been polarity specific and even speaker wire is coded.
Woody
Door Art Collection
Czechman #689554 10/27/2010 12:22 PM
Woody I'm almost positive that's only a concern if you're wiring more than one speaker up. You don't want to get them out of phase with each other, if they are out of phase then they will cancel each other out. All of the output circuits that I've run into are drivin by an audio transformer, and a transformer will only work on AC or alternating DC and as you know an AC plug can be turned in either direction. Just reverse the wires and give it a try.
Maybe Fred N. will step in and offer us a more technical explanation; he is much more of an audio man than I am.
All that said, I thought I was wrong once, but as it turned out I was mistaken!
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
This is a two-speaker thingie and the wires that come off the radio are marked + and -.
Woody
Door Art Collection
Czechman #689565 10/27/2010 1:44 PM
Hook em up and if sound is tinny (no bass) swap wires. It ain't rocket science. The + and - markings are probably on there because they are universal connectors that can be used for most anything.
1952 Chevy 3100
More pictures in Photobucket
Doin better'n some an worse than others. Life's what ya make of it. FAMILY, GOD and COUNTRY. Love it or Leave it.
Czechman #689665 10/27/2010 6:54 PM
You said nothing about the wire being shielded. The shield should be grounded.
Cletis #689701 10/27/2010 10:14 PM
[quote=Czechman]You said nothing about the wire being shielded. The shield should be grounded.
My original post says "The male has no rubber insulation shield but the female does."
Regardless, I flipped a coin and it decided that the insulated plug was positive. Thank you for your help.
Woody
Door Art Collection
Czechman #689828 10/28/2010 4:50 AM
OK, there was a misunderstanding of terminology. A shielded wire has a metal shield around it. An insulator is not a shield.
Cletis #689854 10/28/2010 11:00 AM
There is no polarity with a speaker, as Denny said. The phasing is important with stereo systems so that they don't cancel each other.
1951 1 Ton Completed
Cletis #689856 10/28/2010 12:05 PM
I think from now on I'm just going to preface all of my posts regarding electricity with a disclaimer that, when it comes to this subject, I'm illiterate.
Woody
Door Art Collection
Czechman #689866 10/28/2010 1:21 PM
Thanks for jumpin' in with your expertise Fred.
Now don't cha feel bad Woody, that's why I had to call Fred into the house. Ya see, I've been everywhere but I only know ALMOST everything! Just kiddin I hope ya know.
Since you're so close to hitting the road with your truck, here's a song for you to try out those speakers on.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
