| | | Forums66 Topics128,089 Posts1,056,139 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | Why did they make the dome light "hot" all the time and control the ground through the switch? This requires two wires to the light, when it could have just been powered from the switch to the light and grounded at the case. I assume it has to do with the capability of being able to dim the instrument lights. Think of the miles of wire they could have saved at the factory. Too much trouble to design a switch that would provide power to the light? And why do you need to dim the dash lights? Couldn't they just be off or on? Just wondering. Jeff
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | the dome lite setup is likely because it could then be operated by more than one switch, like door switches as in a car, which had the same headlite switch .... and maybe you don't do much nighttime highway driving, but I kinda prefer being able to see the gauges minus reflection off the glass and without having to flip a switch  Bill | | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | Of course I think the guages should light up, just questioning the need for the adjustment of the light brightness.
1957 GMC 150
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | I thought that's what I answered  " I kinda prefer being able to see the gauges minus reflection off the glass" - on the highway full brightness dash lights reflecting off the windows can get very fatigueing for the eyes, lights at a low level work better in some circumstances, and that's also why aircraft use red light and modern vehicles started going to soft colored light Bill | | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 |
1957 GMC 150
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | The dome light on my '38 is a one wire set up. It grounds to the body with the wire to the switch being hot all the time.
