| | | Forums66 Topics128,005 Posts1,055,261 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 171 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 171 | Boy I just scored big!!! I found a 67-72 3/4 ton gmc In a local yard with the H052 axle with 4.10 gears. looks like brand new on the inside & very little slack ( you want some ). All I'll have to do is replace the pinion seal & I'm good to go. this is going to be a really big improvement in my 50 3800. now that i have my broken speedo needle fixed & cable greased i realize i was going alot faster than i thought i was! now that i actually know that i'm going 50-55 it isn't near as loud. the 4.10s will be way better than the 5.14s going down the road & i'll still be able to pull anything i want too. robert | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 |
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | | | | | | Joined: May 2005 Posts: 235 Shop Shark | | Shop Shark Joined: May 2005 Posts: 235 | SWEEEEEET!!!!  | | | | | Joined: Mar 2005 Posts: 171 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 171 | just got it put in today. Man what a difference! like driving another truck almost. I'm running about 2400 @ 55 with 32" tall 750-17 tires. the 8r19.5s (33") I'm going to will drop it another 75 or so rpm. if you've got a 1 ton with 5.14 gears I highly reccomend this swap. Robert
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | That is what I put in and I am very happy too. | | | | | Joined: Jul 2010 Posts: 10 New Guy | | New Guy Joined: Jul 2010 Posts: 10 | but now the speedo is wrong. WW | | | | | Joined: Mar 2005 Posts: 171 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 171 | of course it is. there are ways to adress this, adapters & such. when I said what rpm i was turning at a given speed i wasn't saying what the speedo actually read. when it says 45 i'm actually doing about 60. check this out: http://www.oldchevytrucks.biz/47_55/full.asp?page=162 | | | | | Joined: Feb 2000 Posts: 69 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 69 | Check out my 3800 at <oldjalopy.com>. That 4.10 3d member is sweet. | | | | | Joined: Mar 2005 Posts: 171 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 171 | beautiful truck! If you haven't done it already put some sway bars on it, you'll love the way it handles. check out my pictures for the install on my truck. I used cpp's sway bar on the front & a front sway bar from a ford explorer in the back. pretty simple job and it didn't do any permanent harm to the truck's originality. even the crossmember I welded on the back could easily be cut off & ground smooth. | | | | | Joined: Oct 2010 Posts: 13 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 13 | What are your plans for the old 5.14? Would you be interested in selling it or trading for any custom cnc plasma work?
The Eaton Axle Guy
| | | | | Joined: May 2005 Posts: 74 'Bolter | | 'Bolter Joined: May 2005 Posts: 74 | Bluechev, did you swap the gear set only? My '62 dually also has the 5.14 gear and I'd like to go with a 3.70ish to 4.10 gear. Thought about swapping out the entire rear end but if just a chunk swap will work I'd go that route instead. Mine has a 283\4 speed. | | | | | Joined: Mar 2005 Posts: 171 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 171 | willy the same rear axle assembly was used in 3/4 & 1 ton trucks from 1947-72 any of the third members will swap into any of the axle housings. 4.10 is probably the best you're gonna get. only other ratios made were 5.14 & 4.57. gm never made any thing else for this axle. an aftermarket 3.9 rring & pinion was produced at one time but know more haven't heard of anyone finding one anywhere. 1 tons usually have 5.14s, 3/4 tons usually have 4.57, unless its a V8 atuomatic truck then theres a good chans it's a 4.10. mine come from a 67-72 gmc 350 atuo truck | | | | | Joined: May 2005 Posts: 74 'Bolter | | 'Bolter Joined: May 2005 Posts: 74 | thanks for the info, bluechev. Found a 4.57 rear end in a local junk yard and the gears look good but that doesn't seem like enough of a ratio change to make much difference in top end speed.
I'll keep looking for a 4.10. | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | Willy,
That 4.57 set should add 5 to 7 mph to your top speed over the 5.14's depending on your tire height and rpm.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I had 5.14 in my 1 ton, and switched (whole axle) for 4.56, and it was much appreciated.
And I agree that 4.10 would be better unless you live in the hills and haul a lot of stuff.
Grigg | | | | | Joined: May 2005 Posts: 74 'Bolter | | 'Bolter Joined: May 2005 Posts: 74 | I had 5.14 in my 1 ton, and switched (whole axle) for 4.56, and it was much appreciated.
Grigg It's definitely a hauler and we have plenty of hills, may have to reconsider this. I use this truck for not only local hauling but also down the highway. It has to be able to do that occasional 300-400 mile road trip and 50-55 mph doesn't really cut it on the highway. | | | | | Joined: Oct 2010 Posts: 13 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 13 | I have a set of 4.57 gears or a full 4.57 third that I could trade you for the 5.14 third.
The Eaton Axle Guy
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | It's definitely a hauler and we have plenty of hills, may have to reconsider this. I use this truck for not only local hauling but also down the highway. It has to be able to do that occasional 300-400 mile road trip and 50-55 mph doesn't really cut it on the highway. Well... My 52 1 ton with 4.56 gears had no problems hauling anything I could fit in the bed, and had no problems with road trips either. Here's a picture of my truck just short of half way through a road trip.. http://rides.webshots.com/photo/2992098450080251109ZixjcaWith a 235 engine 4.56 should be about right from my experience. Sounds like you have a V8, does it have much more HP and torque? If so you may get by with 4.11, but then again might not? Grigg | | | | | Joined: Mar 2005 Posts: 171 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 171 | I have 7.50-17s on the back which are 32" tall. while I don't have much experience hauling any loads yet I have no problems maintaining speed on hills. as a matter of fact I live on a fairly steep mountain & I can start at the bottom going 55 & accelerate to 60 plus by the time I get to the top. I'll admit my way less than stock 261 certainly helps, but I had a 3100 with a stock 235 with the 3.55 gear conversion in it & it pulled the hills pretty much the same way. you guys aren't giving the old stovebolt engines enough credit. with 4.10 gears your truck will do any thing it already does only better. | | | | | Joined: May 2005 Posts: 74 'Bolter | | 'Bolter Joined: May 2005 Posts: 74 | Well... My 52 1 ton with 4.56 gears had no problems hauling anything I could fit in the bed, and had no problems with road trips either. Here's a picture of my truck just short of half way through a road trip.. http://rides.webshots.com/photo/2992098450080251109ZixjcaWith a 235 engine 4.56 should be about right from my experience. Sounds like you have a V8, does it have much more HP and torque? If so you may get by with 4.11, but then again might not? Grigg Grigg, it has a 283 in it now. It had a newly rebuilt 235 which ran great but couldn't haul a load at any speed. With the 235 for example, on a hill with 3,000 lbs of gravel I'd have to drop down to second gear. That same hill w\o a load and I'd be in 3rd gear. Now with the 283 I can pull the hill in 3rd loaded and in 4th empty. So I can definitely run at higher speed and get up to speed faster with the V8. So I guess I'm trying to figure out how the truck would do with the 283 and 4.11 gears while hauling 3,000 lbs. Would it be that much different than a 3\4 ton longbed pickup with 4.11's? I'm not sure what the difference in curb weight is between the dually and a longbed pickup so if the dually weighs a lot more to begin with then maybe the 4.11's aren't a good idea for hauling. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | With that info 4.11 sounds like a good choice for you.
Grigg | | | | | Joined: May 2005 Posts: 74 'Bolter | | 'Bolter Joined: May 2005 Posts: 74 | | | |
