| | | Forums66 Topics128,163 Posts1,056,918 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | | Johnnyc47 Unregistered | | Johnnyc47 Unregistered | Hi Damian,
Yes your right. When the front was flipped, new mounts were welded to the axle...Ill try to remember and get you a picture today. Its so darm simple and a great way to drop a truck with very little cost. | | | | | Joined: Jan 2011 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 68 | dmulally, I didn't get as low as this one, but i took 4 leafs out of the front and it dropped it significantly. and it doesn't ride bad at all. the rubber frame bumpers underneath still sit about 3 inches from the frame. vey cheap, i just had to buy new U bolts due to having to cut the old ones. -DVZ http://s1231.photobucket.com/albums/ee502/dvzdeathtrap/ | | | | | Joined: Jan 2011 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 68 | BTW Johnnyc, your truck is awesome. -DVZ | | | | | Joined: Dec 2010 Posts: 22 New Guy | | New Guy Joined: Dec 2010 Posts: 22 | Great, thanks guys. Look forward to the pics :-) I was going to get the axle bent. | | | | | | Johnnyc47 Unregistered | | Johnnyc47 Unregistered | Got a lot done tonight...Here are a couple of pics...Im going to pull her out tomorrow and get some pics in the daylight. pic 1 pic 2 pic 3 pic 3
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Now that's "Pretty Neat" ! | | | | | Joined: Oct 2007 Posts: 91 'Bolter | | 'Bolter Joined: Oct 2007 Posts: 91 | Nice work ! The paint looks great.It sure is cool to see all you guys having fun with the big trucks. What is the turning radius on your truck? | | |
